Example Code
Check USB Flash Drive Memory Usage on cRIO
Products and Environment
    Hardware
  • CompactRIO/SingleboardRIO
    Software
  • LabVIEW Real-Time Module
  • LabVIEW
Code and Documents
Description
Overview
This VI demonstrates how to check the size and memory usage of a flash drive connected to the USB port of a cRIO.
Description
The Get Volume Info function is used to obtain information about the USB flash drive. Flash drives connected to a cRIO's USB port are recognized as the "u:\" drive.
  1. Unzip the attached file for your version of LabVIEW
  2. Open the Usbdrivetest.lvproj project
  3. Right-click on the RT CompactRIO Target in the Project Explorer window and select Properties
  4. Enter the IP address of your cRIO with USB flash drive inserted
  5. Click OK
  6. Open and run usbtest.vi
Requirements
Software
LabVIEW Development System 2009 "or compatible"
LabVIEW Real-Time Module 2009 "or compatible"
NI-RIO 3.3.1 "or compatible"
Hardware
cRIO controller with USB slot
USB flash drive
Additional Information or References
**This document has been updated to meet the current required format for the NI Code Exchange. For more details visit this discussion thread**
