Example Code
Check if Polymorphic VI without loading in memory
Code and Documents
Overview
Check if a VI Path is a Polymorphic VI type without loading the VI in memory.
Description
Hardware and Software Requirements
LabVIEW 2015 or later
1. Press Run
Additional Information or References
Comments
Darren
Proven Zealot
Proven Zealot
on
Thanks for submitting this example, rcpacini. There is another way to achieve this task that is quite a bit simpler. You can call the following VI:
vi.lib\Utility\lvfile.llb\Get File Type.vi
This VI accomplishes the same task as your VI, without loading the target VI into memory. Get File Type.vi also executes faster than parsing the connector pane data type.
This VI, along with many others, is available in Quick Drop/palettes when you install my Hidden Gems package. Just search for 'hidden gems' in VIPM.
