Introduction
This VI uses the Chirp Pattern VI in LabVIEW along with a Functional Global Variable concept in order to create a Point By Point Chirp Pattern.
 FP.png)
.png)
Description-Separate-2
Hi David. I wanted to implement Chirp generation on FPGA, so i have to generate it without using the CHIRP PATTERN VI, so can you help me in that respect?
I've been looking for a solution to this for quite some time. Were you able to find anything?
