Example Code
Cluster to Xml & Xml to Cluster
Code and Documents
Hi everyone.
I developed "Cluster to xml" and "xml to cluster" converter.I hope more people benefit.
Best Regards.
Himmet GENCER
Comments
jordankuehn
Member
Member
on
What's wrong with the existing LabVIEW primatives?
The Colex Group
Lead Software Engineer
Certified LabVIEW Developer
Himmet
Active Participant Active Participant
Active Participant
on
Himmet
Active Participant
on
Flatten to xml produce unnecessary child.Example value type  ... So produced xml  not simply for other platforms
Nick-W
Member
Member
on
There is more XML in the LV example, but it is there for a reason for it.  The LV primatives will support any LV data type and to do that, the implementation must be more generic.  While the VIs you did will generate easier to read XML, they will fail as soon as you try to convert a cluster with a data type not explicitly supported, such as an array or sub-cluster or event timestamp.
Contributors
