Overview
This example works as Comb filters,which are used in a variety of audio and signal processing algorithms.
Description
Comb filters are used in a variety of audio and signal processing algorithms, include implementing echo and flanging effects. The simplest structure of a comb filter is the feed-forward comb filter that has the form y = x + ax[n-K], where K is an integer delay and a is a scaling constant.
Requirements
Software
Additional Information or References
