Example Code
Combine Dequeued Waveform Elements in a Producer-Consumer Architecture Using LabVIEW
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
This VI dequeues a user-defined amount of waveform elements and combines them for easier processing or displaying.
Description
This VI uses a producer-consumer architecture. Waveform elements are enqueued in the producer loop. When enough elements are present in the queue, the consumer loop dequeues those elements and combines them. This is done by keeping the first dequeued element's t0 and dt values and the combined Y-array values of all the dequeued elements. The output is a combined waveform of all the dequeued elements, on which further processing can be done. This VI can be useful if the timing for the enqueuing of the waveform data is different from the desired displaying or processing.
Requirements
  •  LabVIEW 2012 (or compatible)
  1. Download the VI
  2. Open the "Producer-Consumer Combined Waveform 2012.vi"
  3. Set the Producer Loop timing and the number of Samples to combine
  4. Run the VI
Additional Information of References
VI Block Diagram
** This document has been updated to meet the current required format for the NI Code Exchange.**
Xavier
