Overview
This example divides a string input to an array of elements using different delimiters
Description
This VI takes a comma delimited string input and converts it to an array of strings and an array of numbers. You can choose to use other delimiters if you like, but comma is set as the default.
Requirements
LabVIEW Base Development System 2012 or compatible
Additional Information or References
VI Block Diagram
**This document has been updated to meet the current required format for the NI Code Exchange. **
