Example Code
Communicating with MIDI Device in LabVIEW
Products and Environment
    Software
  • LabVIEW
    Operating System
  • Windows
    Other
  • DryWetMIDI .net library
Code and Documents
Description
This example shows how to use the DryWetMIDI  library to communicate with a MIDI device use .net.
There are examples:
- get list of active MIDI InputDevice and OutputDevice (Count.vi);
- get MIDI device properties (Property.vi);
- sending NoteEvent to MIDI OutputDevice (NoteOutputDevice (Write).vi and NoteOutputDevice (Write On-Off).vi);
- handling NoteEvent from MIDI InputDevice (NoteInputDevice (Read).vi) using callback function (EventReceived Callback Function.vi).
Source code in LabVIEW 2015.
The archive contains the necessary libraries.
In case of problems, create copy of the Melanchall_DryWetMidi_Native32.dll (or 64) libraries in the folder C:\Windows\System32\ or (C:\Windows\System\).
Related Links
DryWetMIDI on GitHub: https://github.com/melanchall/drywetmidi
Demo Video: https://youtu.be/o-EXSJ_Ltac or https://rutube.ru/video/a4abd5eccd67d5c9835a8c5775dfcb90/
Comments
whodat_gavel
Member
Member
on
@IvanLis - THANK YOU for sharing this!!  I have been able to READ and PLAY with the separate VI's, and have a few questions if you could please message me?
IvanLis
Member
Member
on
Hello!
What questions do you have?
Contributors
