Example Code
Communicating with a LabVIEW Web Service using a LabVIEW NXG Web Module WebVI Client
Products and Environment
    Software
  • LabVIEW
  • LabVIEW NXG
  • LabVIEW NXG Web Module
    Operating System
  • Windows
    Programming Language
  • LabVIEW G
Code and Documents
Description
I created a very simple WebVI that acts as a client to the LabVIEW Weather Monitoring Web Service Example included with an install of LabVIEW. This example uses an HTTP call to request data from the Web Service example. I created the WebVI using LabVIEW NXG Web Module 5.0.
In the process of figuring out how to interact with the Web Service example, I used this great tutorial Creating and Publishing a LabVIEW Web Service to the Application Web Server.
How to Use
  • Open up, configure, and run the LabVIEW Weather Monitor Web Service example in LabVIEW 20XX
    • I hosted everything on the NI Web Server. Ensure your Port used is the same open port setup during the NI Web Server Configuration
  • Open the "Weather Monitor Client" WebVI in LabVIEW NXG 5.0. You will also need the LabVIEW NXG Web Module installed.
    • Ensure the IP and Port information match those in your Weather Monitor Web Service.
    • Run the Weather Monitor Server VI
    • Run the Weather Monitor Client WebVI
Related Links
Daniel Parrott
Software Product Marketing - Data Management & LabVIEW
Comments
Slavko_24
Member
Member
on
Thanks a lot, it's really helpful during the first steps!
