Any attached Code is provided As Is. It has not been tested or validated as a product, for use in a deployed application or system, or for use in hazardous environments. You assume all risks for use of the Code and use of the Code is subject to the Sample Code License Terms which can be found at: http://ni.com/samplecodelicense
Overview
NI FlexRIO is a very flexible and powerful product family. For each NI FlexRIO Adapter Modules several Getting Started examples exist.
However, one useful example was still missing. A community example about how to communicate with an ADC and read back its samples successfully (via LVDS signals).
This led to the creation of the following example.
Description
Which ADC?
When we talk about "communicating with an ADC and reading back samples", then of course one of the most important things to know is which ADC we are using.
For this specific example a 4 channel ADC of the type LTC 2171-14 was used.
More information about it can be found in the following datasheet:
http://cds.linear.com/docs/en/datasheet/21721014fb.pdf
As most of you know each ADC has several modes.
In this example the mode "1-Lane Output Mode with 14 bit serialization" as selected for the ADC.
This mode gives you the following ADC Timing Diagram:
The Bigger Picture
When we take a step back and look at the bigger picture, then the Hardware (signal) connections come down to this High-Level Signal Overview:
In this image you notice the following LVDS signals between the ADC ("LTC 2171-14") and the NI FlexRIO Adapter Module:
On each (rising and falling) Edge of this clock signal you will have one bit of the serialized ADC Channel data outputted by the ADC.
The order in which they are serialized is shown in the ADC Timing Diagram.
Writing and or reading data on two different edges of a clock is often also referred to by the acronym DDR (or Double Data Rate). A major benefit is that this allows you to use slower clocks, since you trigger something on both edges.
For a 25 MHz “ENC” Clock this would give the following DCO Clock Frequency:
DCO Clock Frequency = ENCClockFrequency * (14 bits/Sample) * DDRFactor
= (25 MHz* 1 Sample) * (14 bits/Sample) * DDRFactor
= (25 MHz * 14) * DDRFactor =350 MHz * 0.5
= 175 MHz
When using a 175 MHz DCO Clock with the 1-Lane Output Mode with 14 bit, one achieves 350 Mb/s transmission speeds per ADC Channel.
These different LVDS signal look as illustrated below in the time domain. I have taken the liberty to indicate in colors which signals will go from the NI 6587 towards the ADC and vice versa:
Scope
The scope of this examples is limited to:
The configuration of the third party ADC (eg. select the correct mode) and other things that fall outside of this scope are not included in this example.
High Level Architecture
Graphical Representation
This is the Graphical overview of the different parts that constitute the source code of the Example:
FPGA Main VI aka " NI 6587 Communicating with ADC (FPGA).vi "
The FPGA Main VI contains several pieces of code that are documented in the FPGA VIs themselves.
In this document you can find a summary of the most important high-level concepts that need to be understood to be able to go more deeply through the rest of the Example.
You should go through the different subVIs in the code (from top to bottom) to get a complete understanding of the source code.
All VIs should have documentation and the most critical ones will have specific tests written to verify their functional behavior (without having to do a compilation).
LVDS Input Reading and Configuration Loops
High Level Concept:
The actual frequency of this Single Cycle Timed Loop will not be equal to the ENC/ADC Clock Frequency:
This is a simple calculation[1].
For completeness I have included the NI 6587 Input/Acquisition Timing Diagram from the NI FlexRIO Help:
Other Design/Implementation/Test Choices:
Based on the example code, the user should make the following (differential) external hardware connections:
NI 6587 Connector |
ADC Pin-Out |
DIO7 |
OUT3A |
DIO6 |
OUT4A |
DIO5 |
OUT2A |
DIO4 |
OUT1A |
DIO9 |
FR / Frame |
STROBE |
DCO |
DIO0 |
ENC |
In the documentation, you can find more information about the NI 6587 Connector.
In the datasheet of the ADC (http://cds.linear.com/docs/en/datasheet/21721014fb.pdf) you can find the ADC Pin-out.
The Example uses the NI 6587 Serdes Channel CLIP Reference and selects the option Strobe Bypass (5). It also writes this change by using Xpoint_Switch_Write. This is configured before actually starting any of the other loops.
This means that you should physically connect the DCO Output of the ADC with the STROBE Input of the NI 6587. (check STROBE - DCO Connection in the table earlier on)
For transferring the acquired data to the LVDS Deserialization Loop a Target Scoped FIFO (with Block Memory implementation) is used, because this type of Target Scoped FIFO allows you to cross clock domains.
High Level Concept:
We chose streams of 70 bits because this is the least common multiple of the following two numbers:
If one of these parameters would be different, then the size of the stream can become different from 70 bits.
To verify functional behavior of the FPGA Code before compiling it the following (Windows-based) test VIs were created:
To verify behavior during deployment some debugging indicators have also been provided.
Edge Detection Loop
High Level Concept:
To verify the proper behavior of the FPGA Code before compiling it the following (Windows-based) test VI was created:
Sample Selection and Transfer To Host Loop(s)
High Level Concept:
Other Design/Implementation Choices:
To make the code as easily readable as possible two separate loops were created on the FPGA:
This loop handles the selection of samples based on the incoming FREDGE and OUT#A streams.
It creates as its output a cluster of 5 samples (U16) for all of the 4 OUT#A streams.
In total this gives a cluster of 20 samples as shown in the picture:
When this clustered is filled in, it is transferred to the "Transfer To Host" Loop via a Target Scoped (Block RAM) FIFO.
This loop takes/reads that cluster of 20 samples (5 samples for all 4 channels) and splits it up in 5 chunks that contain 4 samples each.
(so: 5 chunks of 4 samples)
This is done in such a way that chunk i contains the ith sample of the OUT1A, OUT2A, OUT3A and OUT4A StreamVals (see previous image).
Below I have added a graphical illustration of how chunks 1 and 3 are constructed:
Since we have in each chunk 4 x U16 samples, we join these 4 x U16s in one U64.
This U64 (that contains sample i for all 4 channels OUT#A) will then be transferred from the FPGA to the Host via a DMA Target To Host FIFO.
Note: This "joining to U64" mechanism is sometimes necessary due to data type restrictions of DMA Target To Host FIFOs
The algorithm for the sample selection was developed with a focus on the LTC2171-14 ADC in 1-lane Output Mode with 14-bit serialization.
Especially the Timing Diagram from the ADC's datasheet was used as an important reference:
Also knowledge concerning the Timing Diagrams of the NI 6587 was used to develop the algorithm:
To verify the proper behavior of the FPGA Code before compiling it the following (Windows-based) test VI was made:
This test VI is the most elaborate one (that is included), because it also handles the most challenging part of the code.
Therefore, it is worth the effort to make a (small) test bench around it, so that its functionality can be simulated before compilation.
LVDS Output Clock Generation and Configuration Loop(s)
High Level Concept:
Note:
The minimum clock frequency required for the ADC was 5 MHz.
The minimum clock frequency of the onboard clock (Si570) is 10 MHz.
Hence, we cannot directly wire through/output this onboard clock to generate a 5 MHz clock.
For this and other reasons (eg. readability) we chose to "overclock" the clock generation with a factor 10 to be able to output the clock signal via an LVDS Generation Channel.
This VI only tests a small portion of the Clock Generation algorithm.
The top level FPGA VI does contain a more elaborate explanation on how this type of clock generation works. This is mostly based on the following Timing Diagram of the NI 6587:
One of the most important things to remember is that the ENC clock will be outputted on the LVDS DIO0 lines. This is also noted in the earlier External HW connection table.
Host/Windows Main VI aka " NI 6587 Communicating with ADC (Host).vi "
The Host/Windows Main VI contains several pieces of code that are documented in the host VI itself.
In this document you can find a summary of the most important high-level concepts that need to be understood to be able to go more deeply through the rest of the Example. You should go through the different subVIs in the code (from top to bottom) to get a complete understanding of the source code.
Input Clock Configuration Code
High Level Concept:
Output Clock Configuration Code
High Level Concept:
The current code is written in such a way that the Windows Host VI should be able to directly run the code for the 6 MHz ADC/ENC Clock.
To change this clock frequency, you can modify the "ADC/ENC Clock Frequency (Hz)" Control on the Front Panel of the Host Main VI and again follow the steps described in the Host Main VI.
The FPGA code in this example is designed for a maximal ADC/ENC clock frequency of 25 MHz.
ADC Sample Reading Loop
High Level Concept:
Debugging Loop
High Level Concept:
Requirements
Software
The following NI software was used to develop this example:
Hardware
This example was made for a set-up that uses the following NI hardware:
To be able to successfully run this example out of the box one should also have the following hardware available and correctly set-up:
Additional Images or Video
N/A
[1] Loop Frequency = (DCO Clock Frequency/5) or 35 MHz (=175 MHz/5)
This is also explained in the ‘NI 6587 Serial Acquisition - Configuration.vi’ its documentation.
This is because the ADC generates 14 useful bits per ENC Clock tick.
The NI 6587 Serder Channel CLIP only provides 10 useful bits per Loop iteration.
(or 25 MHz *14 bits /10 bits = 35 MHz)
Description-Separate-2Example code from the Example Code Exchange in the NI Community is licensed with the MIT license.
This example shows the strength of using the FlexRIO to run, test, and control fast and complex hardware. I wish more examples would look like this one. Actually, the lack of examples of fast FlexRIO applications (>10MHz) is a risk. Even if there is support for high speed it does not help you to develop high speed applications the first time. The outcome for the customer that he or she get stuck during development. I encourage NI to develop more examples similar to the one presented above.
Wonderful explanation, could you please give me same kind of explanation with same example for SERDES Connector CLIP..
Will be very thankful, if you could help !!
Thanks in Advance
Hello
What happens if you start the projet without connect a signal clock to Clock_IN ?
Michael
Hello PriyadarsiniS,
I hadn't seen your post about this until now.
What information are you specifically looking for/missing for the SERDES Connector CLIP?
I won't have the possibility to rewrite the example for the connector clip (no longer have access to the module locally), but I can guide you to additional information resources.
Hello Michael,
Are you referring to the Clock In of the 6587?
The example does not require you to connect an external clock to the Clock In Connector of the 6587.
