Example Code
Compare File Directories Continuously
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
This example looks at a directory in your file system that you specify and either compares it to it's original state, or compares it to another file directory.
Description
This example runs continuously with an auto-indexed For Loop in order to identify if file anomalies exist (disappearing, renaming, etc.). This will allow for the user to run the code continuously in the background in order to monitor the state of a particular directory.
Requirements
LabVIEW 2012 or compatible
1. Select the Original Directory Path on the front panel
2. Select the Directory to Compare Path (if desired)
3. Click the Compare button
4. Run the VI
Additional Information or References
