Overview
The example used the .NET framework to record CPU and memory data and logs this data to a TDMS file.
Description
It is often difficult to track down visually exactly how much memory or CPU are being used on your computer at any point in time. This VI calls into the .net framework and pulls your computer usage out and logs the data to a TDMS file. You can then view the data with the TDMS viewer to see the trends of CPU, memory committed and percentage of your memory used. All you have to configure is how often you want to log your data.
Requirements
LabVIEW 2012 (or compatible)
.NET Framework 1.1 (or compatible)
Additional Information or References
Front Panel of the VI
Windows systems only. Will compile or update if you want to see anything in particular. Just make sure to comment on the usability or anything else.
