Overview
This demonstrated the conditional terminals concept using a numeric array ,and finding the number of instances of values within certain bounds as well as the number of times a Boolean array displays a true or false state.
Description
This demonstrated the conditional terminals concept using a numeric array, this can also be done using the Selector function or case structures, the use of conditional terminals seemed the simplest and most straightforward way.
Requirements
Additional Information or References
Front Panel
VI Snippet
