Example Code
Configuring the Time Synchronization Service Without Lookout or the LabVIEW DSC Module
Products and Environment
    Software
  • LabVIEW
Code and Documents
Description
Overview
This example demonstrates how configure the Time Synchronization Service without installed DSC or Lookout module.
Description
In order to keep data properly time stamped in Lookout and LabVIEW DSC you need to ensure the clocks on the computers are synchronized. The NI Time Synchronization (lktsrv.exe) offers the ability to do that. NI Time Synchronization allows a computer to keep its time synchronized with a master time server, or to act as a time server for other machines.
You can configurate the NI Time Synchronization in the LabVIEW Development Environment, if you select Tools > Options and select the Shared Variable Engine category.
Shared Variable Engine Time Server.pngShared Variable Engine Time Server.png
This Example shows how to configure the NI Time Synchronization Server on the remote client computer that doesn't have the LabVIEW or DSC Development Enivronment Installed.
Requirements
 Software
  • LabVIEW Base Development System 2012 (or compatible)
 Hardware
  • No hardware is necessary to use this example VI
  1. Download and open the attached VI
  2. Run the program
Additional Information or References
Configurate Time Synchronization Service - Front Panel.pngConfigurate Time Synchronization Service - Front Panel.png
Configurate Time Synchronization Service - Block Diagram.pngConfigurate Time Synchronization Service - Block Diagram.png
**The code for this example has been edited to meet the new Community Example Style Guidelines. The edited copy is marked with the text ‘NIVerified’. Read here for more information about the new Example Guidelines and Community Platform.**
Ben Sisney
FlexRIO V&V Engineer
