Overview
This example shows how to control cluster properties for all of the objects contained in the cluster.
Description
This example shows how to control cluster properties for all of the objects contained in the cluster. The example specifically shows how to control the label display, but can be used with other properties as well, as long as they are common to all of the cluster objects.
Requirements
Additional Information or References
Front Panel
Block Diagram
