Example Code
Control Extensions for WebVI
Products and Environment
    Software
  • G Web Development Software
Code and Documents
Description
This example includes utilities to extend the behavior of built-in controls in WebVIs. See an example page using the library.
Note: If you use this library to modify the behavior of built-in controls, these modifications may not persist from release to release. Plan to test your code each time you upgrade to a new version of the G Web Development Software and update or modify this library as necessary. Alternatively you may consider integrating a 3rd party control where you have full control the behavior and upgrade timing.
Button Style
  • Button - Glyph - Create Image URL Style
Chart
  • Chart - History - Clear
DataGrid
  • Data Grid - Column by Index - Set Sorting
  • Data Grid - Column by Index - Set Grouping
DataGrid Style
  • Data Grid - String Column - Create Background Color Style
  • Data Grid - String Column - Create Font Color Style
  • Data Grid - String Column - Create Text Overflow Scrollbar Style
Gauge
  • Gauge - Needle - Set Arrow
GObject
  • GObject - Tooltip - Set
Listbox
  • Listbox - Items - Enable Tooltip
Numeric
  • Numeric - Fill - Set
    • Note: Use for Gauge, Progress Bars, Tanks, and Sliders.
  • Numeric - Scale - Set Maximum
    • Note: Use for Gauge, Progress Bars, Tanks, and Sliders. Numeric Textbox should use Property Nodes instead.
  • Numeric - Scale - Set Minimum
Panel
  • Panel - Background - Extend
Tab
  • Tab - Selector - Visible
Tree
  • Tree - Cells - Enable Tooltip
  • Tree - Column - Set Width
Changelog
Release 9: Add Numeric - Fill - Set VI
Release 8: Add GObject - Tooltip - Set VI
Release 7: Updates for G Web Development Software 2022 Q3 Patch 2
Release 6: Add Chart - History - Clear VI
Release 5: Button and Data Grid style APIs and finish migrating the deprecated Declarative Style for WebVI example
Release 4: Minor: Fix icon for Gauge - Needle - Set Arrow VI
Release 3: Add Gauge - Needle - Set Arrow VI
Release 2: Add Data Grid - Column by Index - Set Grouping VI and finish migrating the deprecated Control Tools for WebVI example
Release 1: First release available on the community
Milan
Comments
irfanabid
Member
Member
on
This is quite useful example, thanks a lot. I modified the datagrid slightly to have text alignment (left/center/justify).
Thanks & Regards,
Irfan
(CLD)
https://haliatech.com/
Contributors
