Example Code
Controlling E5062A VNA with GPIB
    Other
  • VBA
Code and Documents
Description
I'm trying to setting up a connection between E5062A VNA and a computer (more precisely in VBA).
I just installed drivers ni-488.2_21.5_online and ni-visa_21.5_online. When my VNA is connected through GPIB/USB, I can see it with NI MAX software and I can even send the command *IDN? to obtain the VNA parameters :
01 [joined file 01.png]
My VBA code is :
Sub test()
Dim ioMgr As VisaComLib.ResourceManager
Dim Equip As VisaComLib.FormattedIO488
Set ioMgr = New VisaComLib.ResourceManager
Set Equip = New VisaComLib.FormattedIO488
Set Equip.IO = ioMgr.Open("GPIB0::1::INSTR")
'Equip.WriteString "*RST"
'Equip.WriteString ":SYST:PRES", True
End Sub
I'm trying to setting up the connection (this doesn't work) and tried a reset of VNA, but I already got an error with the "Dim ioMgr As VisaComLib.ResourceManager" line :
02 [joined file 02.png]
I already did a communication with a E5063A with only USB cables and a VBA soft and it worked, that's why I don't understand my mistakes. I also read some Keysight pdf docs with many pages but nothing really helped me. I'm sorry if I'm not in the good forum section.
Thanks a lot for future answers!
Comments
tolltroll
NI Employee (retired)
on
Hi axiome,
Your post looks like it would be better suited for the Instrument Control Discussion Forum. Would you mind creating a new post in that forum?
Thanks!
N
Contributors
