Example Code
Convert Binary Data to Scaled Data in DAQmx
Products and Environment
    Hardware
  • Data Acquisition (DAQ)
    Software
  • LabVIEW
    Driver
  • NI DAQmx
Code and Documents
Description
Overview
This example shows how to acquire raw data (I16 format) and convert it back to a scaled voltage value using two different methods in DAQmx. his example shows how to call a targeted Windows' application (i.e. Calculator) using the System Exec VI.
Description
This example shows how to acquire raw data (I16 format) and convert it back to a scaled voltage value using two different methods in DAQmx.  The first method is manually scaling the voltage by using the equation "Voltage Reading = (binary reading/2^bit)*(Vmax-Vmin)".  The second method uses the DAQmx Channel property node: AI Device Scaling Coefficients to convert the binary data to scaled voltage.
Requirements
Software
  • LabVIEW 2012 or compatible
  • NI-DAQmx 9.5.5 or compatible
Hardware
  • NI Multifunction DAQ Device
  1. Set physical channel.
  2. Set parameters.
  3. Run the VI
Additional Information or References
Check out this article to learn more about scaling binary values: https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019YLoSAM&l=en-US.
Jordan F
