Example Code
Convert Black/White Image to Color Image using LabVIEW
Products and Environment
    Software
  • Vision Development Module
  • LabVIEW
Code and Documents
Overview
This example returns the locations of all the pixels included in the particles found by the particle analysis VI.
Description
This VI takes a greyscale image and converts it to a color image.
Requirements
 Software
  • LabVIEW Base Development System 2012 (or compatible)
  • NI Vision Development Module 2012 (or compatible)
 Hardware
  • No hardware is necessary to use this example VI
  1. Download and open the attached file
  2. Run the program
Additional Information or References
Black and White to Custom Color LV2012 NIVerified.vi - Front Panel.pngBlack and White to Custom Color LV2012 NIVerified.vi - Front Panel.png
Black and White to Custom Color LV2012 NIVerified.vi - Block Diagram.pngBlack and White to Custom Color LV2012 NIVerified.vi - Block Diagram.png
**The code for this example has been edited to meet the new Community Example Style Guidelines. The edited copy is marked with the text ‘NIVerified’. Read here for more information about the new Example Guidelines and Community Platform.**
