Example Code
Convert DAQmx Task Name/DAQmx Global Channel/Resource Name to String
Products and Environment
    Hardware
  • Data Acquisition (DAQ)
    Software
  • LabVIEW
    Driver
  • NI DAQmx
Code and Documents
Overview
This example illustrates how an array of DAQmx Task Name/DAQmx Global Channel/Resource Name can easily be converted to an array of string and then subsequently back to the original array.
Description
Observe the VI Block Diagram. There are essentially two tasks: one which converts an array of Resource Name to an array of string and back; and another which performs a similar task for a DAQmx Task Name. This technique will work for any such resource name. Notice the array constant of resource name to the left of the Block Diagram.Notice that the array of resource name is firstly converted into an array of string. This would facilitate the process of making programmatic changes to the items in the array.Notice that this array of string is then converted back to the original array of resource name. This array of resource name can then be passed to the appropriate driver function as is demonstrated in the Diagram Disable Structure.
Requirements
Software
  • LabVIEW 2012 or compatible
  • NI-DAQmx 9.5.5 or compatible
Hardware
  • NI Multifunction DAQ Device
  1. Download the VI
  2. Run the VI
