Example Code
Convert JPEG String to LabVIEW Image
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
This VI converts JPEG string to LabVIEW image.
Description
You can convert JPEG string to LabVIEW image. This is particularly useful if you wish to view the image of JPEG string on VI.
Requirements
  • LabVIEW Base Development System 2012 (or compatible)
  1. Unzip the attached folder to your computer
  2. Open the VI "DOTNET – JPEG String to LabVIEW Image 2012 NI Verified.vi"
  3. Enter JPEG string
  4. Run the program
Additional Information or References
In case you need JPEG string to check the functionality of this example, you can find example code on the same web page that loads user-specified JPEG file and converts LabVIEW image to JPEG string.
