Example Code
Convert Temperature Units in LabVIEW
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
This code allows the user to Convert Temperature from Selected Unit to an Output Units.
Description
This VI uses a couple of nested For Loop to handle the three possible Input Units and Output Values (Kelvin, Celsius and Fahrenheit). Depending on the combination of Input Units Value and Output Units Value the Tempertature Value is converted applying the calculations.
Requirements
LabVIEW 2012 (or compatible)
  1. Set Input Units, Output Units and Temperature
  2. Run VI
Additional Information or References
 Check out LabVIEW FPGA Temperature Converter for a different look at temperature conversion.
Dan King
