Overview
Conversion between a parallel stream to a serial stream, or from a serial to parallel stream.
Description
In OFDM is a normal practice to shift between parallel to serial streams, or the other way around. The way it is configured depends on the amount of sub-carrier frequencies, and the amount of bits per symbol required. After knowing these information, we are able to switch from one to the other.
Requirements
LabVIEW 2012 (or compatible)
1. Open the "Conversion between Serial and Parallel Streams LV2012 - NI Verified.vi"
2. Choose the amount of bits per symbol and how many sub-carrier frequencies.
3. Select if you would like to transform from Serial to Parallel, or from Parallel to Serial.
4. Select the Run button.
Additional Information or References
