Overview: Sometimes it maybe desirable to convert an ASCII value into a Hex value while preserving its representation.
Description:
If we have the value 6C in ASCII and we want it in Hex to also be 6C, we would have to perform an operation to convert it. This VI performs the conversion by reversing the process in this community example.
Requirements: LabVIEW 2012 (or compatible), Hardware: none.
Steps to Implement or Execute Code:
1. Enter ASCII string.
2. Run the VI.
Additional Information or References:
It only handles the first four characters as is.
Hello... Can someone convert this to Labview 8.5? Thanks
Thank you, it worked perfectly with labview 2015 Ver 15.0 ![]()
