Overview
This example shows one way to convert an analog signal to a digital signal using LabVIEW.
Description
It monitors an analog input signal, and outputs a corresponding digital high or low depending on what the analog voltage is. If the voltage rises above 2.8V, a digital high is output. If the voltage drops below 0.8V, a digital low is output. As a note, we can leverage hysteresis fuction if we encounter any bouncing issue.
Requirement
LabVIEW 8.2 or compatible
NI-DAQmx 8.9 or compatible
Step to execute code
Additional Information or References
VI Snippet
