Example Code
Convert hours to days, hours, minutes and seconds text string
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
This VI demonstrates how to convert hours in decimal format (fraction of hours) to a string containing days, hours, minutes and seconds with units.
Description
Here is a brief description of the example:
The example uses Quotient & Remainder function to extract days, hours, minutes and seconds from the Hours value. The values are converted to strings and their units appended.
E.g.: 1225.576 displays as "51 days, 1 hour, 34 minutes, 33 seconds"
The Hours input value is in decimal format, e.g. 1.5 equals 1 hour and 30 minutes. The result is output as a string and as a cluster. The vi is called from a parent vi. You can easily change the input from hours to seconds if need be as long as the unit of the values fed into the for loop is seconds
Requirements
  1. LabVIEW 2012 (or compatible)
  1. Load the vi
  2. Enter an hour value in Hours
  3. Run the vi and observe the output
  4. Call the vi from a parent vi
Additional Information or References
VI Snippet
