Example Code
Converting Between Arcade Steering and Tank Steering
This document describes the process of converting your FTC teleop VI between arcade steering and tank steering.
1. Open FTCTeleopBasic.vi. (<Program Files>\National Instruments\LabVIEW 2009\examples\FTC Toolkit\Templates)
2. In the true case of the case structure, delete the two blue integer wires connected between FTC Robot
Status.vi and Calculate Power from Joystick.vi. See below.
3. Click the polymorphic VI selector of the Calculate Power from Joystick VI, where it says Arcade, and select
Tank.
4. Connect the Y output of the FTC Robot Status VI to the Left Joystick input of the Calculate Power from
Joystick VI.
5. Connect the Y2 output of the FTC Robot Status VI to the Right Joystick input of the Calculate Power from
Joystick VI.
6. See result below.
6. Done!
Tanya Visser
LabVIEW Group Manager
Contributors
