Example Code
Converting TDMS to Excel with Report Generation Toolkit
Code and Documents
Overview
This example VI illustrates the use of Report Generation Toolkit to Convert TDMS to Excel.
Description
This example was created for a specific case where use of the TDM Excel Add-In for Microsoft Excel was not an option. This code also automatically creates the TDMS files as Excel files instead of having to open each TDMS file and save it yourself or programmatically.
Requirements
  • LabVIEW 2012 (or compatible)
  • Report Generation Toolkit 2012 (or compatible)
  1. Open the project “TDMS to Excel.lvproj”
  2. Open the VI " TDMS to Excel 2012 NIVerified.vi"
  3. Select file paths.
  4. Run the program
Additional Information or References
VI Block Diagram
 **This document has been updated to meet the current required format for the
Comments
ZY_Ong
NI Employee (retired)
on
If you found out that the VI has broken arrow, check this KB out:
Report Generation Toolkit VIs Broken After Updating Office 365
Senior Technical Support Engineer | CLD CTA | NI
DISCLAIMER: The attached Code is provided As Is. It has not been tested or validated as a product, for use in a deployed application or system, or for use in hazardous environments. You assume all risks for use of the Code and use of the Code is subject to the Sample Code License Terms which can be found at: http://ni.com/samplecodelicense
