Overview
This VI can be used as a template for reconstructing vertically interlaced images where the frame grabber does not support the needed tap configuration of the camera.
Description
This example uses the image of a Full Configuration Camera Link Camera where the camera is sending 10, 12, 14 or 16-bits per pixel and 4 taps vertically interlaced. The framegrabber only supports an 8-bit and an 8 tap configuration. It is configured to accept these taps vertically interlaced. This VI reconstructs that configuration.
Requirements
Software
Hardware
Additional Information or References
**The code for this example has been edited to meet the new Community Example Style Guidelines. The edited copy is marked with the text ‘NIVerified’. Read here for more information about the new Example Guidelines and Community Platform.**
