Overview
This example VI shows how to use the Wait function of an outer loop and simple logic to continuously update a nested while loop which will count the amount of time left until the main loop will run again.
Description
This code is particularly useful for programs that have extremely long loop wait values, and allows the end-user to see how long until the loop will execute again. This prevents confusion in cases where a user thinks a VI has frozen because he/she updates a front panel control but does not see the change update due to a Wait function.
Requirements
1.Write the time in the Wait Time control.
2.Select the format in the Display Format control,
3.Run the VI.
Additional Information or References
VI Snippet
