Overview
This example increments a counter when an edge is detected.
Description
The two loops in the provided code demonstrate two functionally identical ways to store the counter value. The top loop demonstrates how to store the counter value in a shift register and the bottom loop demonstrates how to store the counter in a feedback node. The two loops also demonstrate that the use of an inverted input on a compound AND function allows a developer to easily switch between detecting a rising or falling edge.
Requirements to Run
Additional Information or References
VI Block Diagram
