Example Code
Counting Analog Rising Edges when Passing Threshold in LabVIEW
Products and Environment
    Software
  • LabVIEW
Code and Documents
 Overview
This example shows how to count how many times a signal crosses a threshold while increasing only
Description
This example shows how to count how many times a signal passes a threshold while increasing only. This means that if the signal crosses the threshold while it is decreasing, this will not be counted.
Requirements
LabVIEW Base Development System 2012 or compatible
  1. Enter the Threshold value
  2. Enter the Input Signal values
  3. Run the VI
  4. Notice that Counter shows the number of times the signal rises above the Threshold
 Additional Information or References
VI Block Diagram
**This document has been updated to meet the current required format for the NI Code Exchange. **
Efrain G.
Visit http://www.ni.com/gettingstarted/ for step-by-step help in setting up your system.
Comments
JohnCaipa
Member
Member
on
Thanks for the example helped me a lot.
glskinner
Member
Member
on
Thank You greatly for this code...it helped me a lot. But, in order for you to get rising edges you need to switch the two values shown. They're backwards. snip1.png
