Example Code
Counting Up and Down using Shift Registers and Feedback nodes with LabVIEW
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
This small example shows how to use shift registers and feedback nodes to count up and down within a set range.
Description
In this example, feedback nodes and a shift register used for, count up and down between the lower value and upper (minus 1) every 250ms. To use in a SubVI have the stop value a true constant and output from the shift register.
Requirements
Software:
  • LabVIEW 2012 (or compatible)
1. Run VI.
2. Observe that VI will count up and down the value which is defined and stored in shift register.
Additional Information or Resources
