Example Code
Create 2D Array Subset based on values in the first row
Code and Documents
Overview
This example VI shows a way to create a subarray of a 2D array which consists only of columns that fall within the boundaries that you set.
Description
This VI uses some example data in a 2D array and manipulates it so that you can create a subarray which consists only of columns that fall within the boundaries that you set. An example of when this could be of use is when storing data in an array where the first row represents the time domain and all other rows are the data associated with each time. You may only want to see data that has a time value of 3.X seconds or similar.
Requirements
  • LabVIEW 2012 (or compatible)
  1. Download the attached folder to your computer
  2. Open the VI "Sort 2D array By First Row 2012 NIVerified.vi"
  3. Input the "Searching Number"
  4. Run the program
Additional Information or References
VI Snippet
David B
National Instruments UK
