Example Code
Create Digital Pulse Waveform Using LabVIEW
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
This VI creates a digital pulse waveform.
Description
You can specify the sample rate, number of samples, and the pulse rate to create a user-defined digital pulse waveform.
Requirements
  • LabVIEW 2012 (or compatible)
  1. Download the attached VI.
  2. Set up the sample rate, number of samples, and the pulse rate.
  3. Run the VI to generate a digital pulse.
Additional Information or References
VI Snippet
Bryan H.
