Example Code
Create a Hidden Debug Tool in LabVIEW
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
LabVIEW contains a wide variety of debugging tools (probes, highlighting execution, single-stepping), but sometimes it's useful to place an indicator on the front panel to debug a program. However, the user may not want to see the indicator all the time. This VI shows how a user can use visability properties to toggle whether or not an indicator is shown rather than deleting and replacing the indicator when debugging.
Description
This VI demonstrates the ability to "hide" a debugging object in your application.  By pressing the "down" arrow key you can toggle the visibility of a set of waveform charts that records the mean and standard deviation of a set of data from an express VI.
Requirements
Software
  • LabVIEW 2012 (or compatible)
1.Run the VI
2.Press the down key to toggle the debug window visibility.
Additional Information or References
Rick C.
