Example Code
Create a Step Function Waveform
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview: This VI will build a waveform of a step function with a set number of steps.
Description:
This VI will build a waveform of a step function with a set number of steps. It uses for loops with shift registers to increment the amplitude of a square wave and then add these square waves together to get the desired waveform.
Requirements: LabVIEW 2012 (or compatible), Hardware: none.
Steps to Implement or Execute Code:
1. Insert parameters.
2. Run the VI.
3. Look at the graph.
Additional Information or References:
Doug Farrell
Solutions Marketing - Automotive
National Instruments Automotive Solutions
