Example Code
Create and Write to New File When Button is Pressed
Products and Environment
    Software
  • LabVIEW
Code and Documents
 Overview
Coding that exemplifies how to start writing to a file at the press of a button.
Description
This examples shows how you can use a case structure to start writing to a new file at the press of a button.
We are using a "First Call?" VI to make sure that we create a new file on the first iteration. On subsequent iterations we will go to the "False" case by default, and go back to the "True" case when the button is depressed. The "True" case of the case structure creates a new file path based of the current system time, and passes that file name around the While Loop using a Shift Register. The "False" case uses the file path from the previous iteration, and writes new data to the file.
Requirements
LabVIEW 2012 (or compatible)
1. Select the Run button.
2. Move the switch to record.
3. Stop the VI with the Stop Button.
4. Check on the same path as the VI a .xlsx file.
Additional Information or References
Justin Parker
Product Support Engineer
