Overview
This example demonstrates how you can customise the right click in your LabVIEW VI. This is very usefull when you would like to right click on a control or indicator and depending on the option the user selects (which are specified from the programmer) different functionality can be observed.
Description
Requirements
Software:
Additional Information or References
VI Block Diagram
hi
regarding the same... i would like to mention my query .. i want to perform 3..4 tests using labview.. each test will include a seperate VI .so my question is , it it possible to make function which will allow user to select the required VI from a drop down list in same labview window/VI
THANKS IN ADVANCE...!!
please help me...
