Overview
This VI exemplifies how to add the functionality of the "replace or create with confirmation" for the TDMS Open function.
Description
This VI use dialogs to get a confirmation from the user.
Requirements
LabVIEW Base Development System.
1. Load "TDMS Open create or replace with confirmation LV 2012 - NI Verified.vi" with a valid input path.
2. The file path should be a file with a *.tdms extension. Otherwise, LabVIEW will add a *.tdms extension to whatever file name you provide, and the "check if the file exists" VI will not find the file under that new file name next time.
Additional Information or References
