Overview
This VI will create a manifest file for a scene containing a robot and an obstacle.
Description
The Robotics Module requires a manifest file in order to start a simulation. This file contains information regarding the robots, scene and obstacles that will be simulated; while it may be created from a wizard, a new scene may be created or modified with the Offline Configuration Vis.
This VI creates a manifest file to be used in a simulation that includes a starter kit robot as well as a sphere. The properties of the robot and obstacle may be modified from their respective property nodes.
Additionally, if more obstacles or robots are required, it would be a matter of building them into an array before the Simulator Engine property node. This example also contains a small VI similar to the one that is created when using the wizard. Use it to load a simple simulation with the manifest file.
Steps to Execute
Requirements
Software
LabVIEW 2012 with the Robotics Module
VI Snippet
