Overview
Coding that exemplifies how to generate circles on a XV Graph.
Description
This VI allows the user to programmatically create circles at any location on a XY graph. While the program is running, you can add more circles and change their locations. The user can also use the slide bar to change the radius of the circles.
Requirements
LabVIEW 2012 (or compatible)
1. Run the VI
2. Add elements into the arrays in order to generate more points
3. Move the Radius slider to change the radius of the circles
4. Stop the execution with the Stop button.
Additional Information or References
