Example Code
Creating Digital Display using LabVIEW
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
This example VI creates a digital display similar to the one you see on old digital clocks.
Description
This example VI can take any positive integer less than 99999 and convert to the digital display by breaking down the number into its component parts and then placing them into an array. The VI uses custom controls consisting of LEDs and clusters to create the digital display.
Requirements
  • LabVIEW Base Development System 2012 (or compatible)
  1. Unzip the attached folder to your computer.
  2. Open the VI "Digital Display 2012 NIVerified.vi".
  3. Run the program.
Additional Information or References
VI Front Panel
Larry Colvin
Associate Principal Engineer
Dyson Technology Ltd.
