Example Code
Creating Dynamic Probe in LabVIEW
Code and Documents
Overview
This example uses a custom probe that allows the user to quickly analyze their model.  This probe will allow you to view your transfer function during execution.
Description
For closed loop control and model simulation, it is helpful to see your transfer function as it is executing.  The normal LabVIEW probe shows numerical values on wires but not transfer functions.  This example contains 2 parts: a custom probe and a demo VI using the probe.  To view the probe, open "TF Probe.vi"; open "Dynamic Probe Main VI.vi" to view the implemented probe.
You can create your own custom probes similar to this one.  Please look through the "TF Probe.vi" to understand how to develop your own probes.  While this example has a custom probe for transfer functions, you can develop a custom probe for any application.  Because this example is targeted at Transfer Function Models, you will need the LabVIEW Control Design and Simulation Module to run this code.
Note: This particular custom probe only supports Transfer Function Model
Steps to Execute Code
  1. Download and Extract all Files
  2. Manually place "TF Probe VI.vi" in the C:\Users\...\Documents\LabVIEW Data\Probes folder.
  3. Open "Dynamic Probe Project.lvproj"
  4. Open "Dynamic Probe Main VI.vi"
  5. Add the custom probe to a wire by right-clicking on the wire, then select "Custom Probe > TF Probe.vi"
  6. Run "Dynamic Probe Main VI.vi" and view the block diagram to view the probe.
Requirements
Software
LabVIEW 2009 or later
Additional Images
Andy Chang
Contributors
