Example Code
Creating a Scrollbar and Adding to a Waveform Graph Using Property Nodes
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
Coding that exemplifies how to use a horizontal slider to mimic the behavior of a scrollbar on a graph using property nodes.
Description
Waveform charts have built in scrollbars, but waveform graphs do not. You can use Property Nodes to achieve the same functionality on a graph by using a slider.
The VI generates 1000 random numbers and plots them on both a chart and a graph. The chart scrollbar is visible, and you can scroll through the points, displaying 100 at a time. Using the value of a slider to control the minimum and maximum value of the display area on the graph, you can obtain the same effect as a scrollbar. This code consists on inserting a random number into an array depending on what the user chooses. Within the options the user has, we can select either to insert a value at the beginning, the end, or at any specific index.
Requirements
LabVIEW 2012 or compatible
1. Rum the VI.
2. Move the slider to scroll on the Waveform Graph.
3. When desired, finish the execution with the Stop button.
Additional Information or Reference
