This VI allows the user to configure up to 32 channels of digital data for combinatorial triggering.
Applies "Mask Input" to "Trigger Input Line(s)" and returns the result as T or F for use as a custom digital trigger on FPGA based hardware. (cRIO, R Series) Mask options include "And", and "Or" and like lines do not need to be adjacent. "Trigger Line(s) Input" must be array of size = 32. Right-click array and select "set dimensions" to adjust. Lines not used can be masked out by selecting "Ignore" in the mask array. Change control:
Added documentation and implemented single-cycle timed loops in subVI's for optimization.
