Example Code
Custom Pop-up Message with Timer
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
To achieve a Pop Up Box to display message without user interaction, and have it close after a duration of time automatically.
Description:
This example would shows you how to get a pop up box to display message, inputted from the string control on the front panel
Instructions:
To implement this example:
  1. Input the string value to the Message Control
  2. Run the VI
To execute this example:
  1. Install the required software.
  2. Open the VI and refer the Implement Steps
Requirements
Software
LabVIEW 2012 or compatible
Hardware
Best Regards,
Jignesh Patel
Principal RF Software Engineer
Comments
PaulG.
Active Participant
Active Participant
on
Please don't post just 7Z zip files. If you must post both 7Z and windows compatible.
PaulG.
Retired
