Overview
This VI allows for programmatic control over visible array index on the front panel. The example uses Boolean buttons with an event structure but the same logic could be used to implement this programmatically.
An example of a use for this would be for cycling through an array of clusters containing calibration or test parameters. Once a test is completed/ calibration is deployed the user is invited to configure the next whilst saving space on the front panel.
Description
This VI is an example of programmatic control over the top left displayed array index (if you are only showing one element of the array then you can cycle through individual elements). This example uses an event structure to allow control through Boolean buttons.
It is set up so that the array is circular. i.e. if you press "Next" on the last element you will be shown the first element.
Requirements
Additional Information or References
Front Pane
Block Diagram
**This document has been updated to meet the current required format for the NI Code Exchange. **
