Example Code
Cycle through File Names Grouped in a Common Folder
Code and Documents
Overview:
This code Creates an Array with the file paths of all the files on a folder.
Description:
This code makes usage of a list folder VI to get the names of all the files in the folder. Then using the build path VI and a for loop a file path is created for each file.
Requirements:
LabVIEW 2012 (or compatible).
Steps to Implement or Execute Code:
1. Select the folder containing the files.
2. Run the VI.
Additional Information or References:
"**This document has been updated to meet the current required format for the NI Code Exchange.**".
