Example Code
D flip-flop with Set & Reset using Select Function
Code and Documents
Overview
This VI demonstrate the method to developed D-latch flip-flop controls.
Description
A D-latch flip-flop is developed using one of the most common function "select" and avoid feedback register in vi. So one can implement the logic without while loop also.
Requirements
  • LabVIEW 2012 (or compatible)
  1. Download the attached folder to your computer
  2. Open the VI " D flip-flop with Set & Reset 2012 NIVerified.vi".
  3. Run the VI.
  4. Play with the buttons.
Additional Information or References
VI Block Diagram
Comments
Coquinho
Member
Member
on
THanks for this FF is good.
